| hey guys, ive had rough idle issue for a while now and made a video of my live time blatz software was wondering if anyone could help diagnose issue from video? link: [ http://www.youtube.com/watch?v=pOonMEHO1GM ] here is a list of things i have done so far to address the idle issue: removed IAA unit + air controler from rear of motor, diss-assembled cleaned, re-assembled then tested, both units worked and tested properly. ohmed injectors + ignition coils, all ohmed out within spec. removed and cleaned MAF, filaments were still intact and were cleaned with contact cleaner then air dried before re- installed. clean throttle bodies + tested TPS, had proper voltage at idle and at WOT fuel filter is only 2 years old along with 02 sensors spark plugs are NGK PFR6G-11 (3 months old) car has brand new efi harness (2-3 years old) Brand new K&N cone filter 60k timing belt +pulleys & tensioner, oil seals, oil pump, water pump + thermometer, radiator (3 months old) motor has around 65k, with aiv, prvr, egr deleted. headers and complete 2.5" id exhaust jim wolf chipped ecu upgraded clutch and flywheel under pulley with accessory pulleys one piece drive shaft new alternator, battery, and rebuilt P.S pump
